aligning camshafts after removal
Before I get it all apart I'm trying to understand something about the camshafts...if I take them out to replace the seals, how do I keep them aligned? I mean the two camshafts from a single bank. I've read up on other threads and I know I can use the cam locking tool to get one cam into the right position...but how do you make sure the other cam is correctly lined up? Will I need to just make sure the cams don't turn relative to each other once I take them out, or are there marks to get the 'second' cam lined back up?
Or, should I just try to replace all the seals without removing the cams? I do have the special tool to compress the tensioner.
Thanks!I know all this might be obvious when I get to it but I won't be near a computer when I do so I am just trying to be as prepared as possible.
It's delicate work under the tensioners--you don't have a lot of room, and you want to make sure to clean out any dirt, old gaskets, sealer, etc. I used carb cleaner and a small wooden popsicle stick to scrape off stuff. Don't want to nick any surfaces under there.
To get to the cam oil seals behind cam sensors, you have to remove the trigger wheel (13mm bolt), but you don't want cams to move. I held the intake cam with a pair of channel-lock pliers between lobes (very carefully, don't want any metal to come off cam). Same for torquing trigger wheel bolt after installing new seal. Be careful with trigger wheel, it bends very easily.
Take your time, be careful, and you'll get it done. Good luck.
To reinstall, just eyeball.
As far as removing the end caps to get to the cam seals and caps, this works well front and rear on both sides.
