Question about a window, and its not the guides...
Old Apr 11, 2012 | 02:40 PM
Philhawtin's Avatar
Default Question about a window, and its not the guides...
So my passenger window drivers side only rolls up and down when the door is open... What could the explanation possibly be? switch bad?
when i lock the car with that door open, it doesnt honk until the door closes so id say the switch isnt bad.... i dont know..
Old Apr 11, 2012 | 02:44 PM
SloopJohnB@mac.com's Avatar
Tech Guru
Tech Guru
Most likely a partially open wire. When the door is open the wire/circuit makes contact. Get into the wiring harness at the door and find the stretched wire. Or you can wait until the problem goes full time and then find the open circuit with a DVOM.
Frankly, I'd probably wait until it goes solid failure...much easier to trace. Who really cares about the passenger side window anyways.
Old Apr 11, 2012 | 04:28 PM
4Driver4's Avatar
Tech Guru
Tech Guru
VAG-COM is your friend.
Old Apr 11, 2012 | 06:49 PM
GTA_Driver's Avatar
Tech Guru
I would second the broken connection in the wire. Pull the rubber boot off a bit, check the wires.
I had all sorts of mayhem when the rear left door wiring started breaking apart inside the boot.
Beats me why that door failed and not the driver's.
Old Apr 12, 2012 | 04:23 AM
Philhawtin's Avatar
My VAG-COM crapped out on my as of recent... computer says cannot see interface.
Gotta make that call.
Old Apr 12, 2012 | 04:25 AM
Philhawtin's Avatar
Is there a write up on this? Or should i just trace from where the wires are coming out of the frame and trace into door?
Literally looking for failed wire jacket and insulation right? exposed wire?
bsherwoo
Sep 12, 2008 02:05 PM
mcorrow
Feb 1, 2006 07:23 AM
SteveAngry
Jun 19, 2001 04:54 PM
TASTT
Jun 8, 2001 04:43 AM
Joose
Mar 27, 2001 12:22 PM
