Oil leaks and transmission leaks
oil leak around passenger-side turbo. now im not sure if it is the turbo, or more likely, the valve cover gasket/etc. i can see oil on both and am assuming its the valve cover, however; if the passenger side turbo is known to leak from a specific area id like to know to fix it asap!
transmission fluid. jacked up the car and a pool of what looked like transmission fluid poured out of the bottom cross-member. now the fluid was clear on the ground, but apon wiping up with a paper towel, looked pinkish. my question is where could the transmission be leaking? i looked all over the unit as well as up into the bell housing and saw NO, path of fluid leaking out. now, my coolant temp sensor oring is shot and is seeping out coolant as i can see it pink stained around that area. is it possible that there is oil from the valve cover seeping out can flowing over the coolant picking up the pinkish color? or that the coolant is flowing over the oil picking up its viscosity? or is it more likely i have a transmission leak on my 6 speed?
thanks for the input guys
Could be auto trans fluid if someone put the wrong stuff in, but your six speed removes that possibility.
Oil leaks need to be checked with a mirror around the valve covers and tensioner seals. Start from the top and work your way down when searching oil leaks.
4driver4 - your right on about the cam tensioner, how much of a PITA is that to do?
