How to align camshafts? I messed up.
Old Apr 16, 2012 | 06:02 PM
corvuswatch's Avatar
Default How to align camshafts? I messed up.
Hi again! Thanks for all your help on my locking pin question.
My new problem involves the camshafts. I removed the tensioner and both camshafts in order to replace the cam chain tensioner pads. In so doing, one of the camshafts fell off the chain. My alignment marks (magic marker) seem to have disappeared. Now the cams are out of adjustment to each other.
How can I get the camshaft in the right position? The one camshaft has the diamond key that I can use with the bar tool to get it correctly positioned to TDC in relation to the cam on the other bank. But how do I adjust the other camshaft to the proper position? Are there any factory marks on the cam sproket that I can use to line up with the mark on the cam cap arrow?
2.8L 30v 1999 A-6. The crankshaft is locked with the pin.
HELP!!
Thanks,
Mike
Old Apr 16, 2012 | 06:27 PM
4Driver4's Avatar
Tech Guru
Tech Guru
Check the tech section for the cam adjuster seal write-up. There are marks on the cams.
Old Apr 16, 2012 | 07:04 PM
Thanks! I'm not sure which write-up you mean. I've read all that seemed relevant. Kris Hansens? He doesn't remove the camshafts at all. Any help would be greatly appreciated!
Mike
Old Apr 16, 2012 | 07:19 PM
SloopJohnB@mac.com's Avatar
Tech Guru
Tech Guru
Here's one:
http://www.audiforums.com/forum/diy-...er-diy-112177/
Old Apr 17, 2012 | 09:10 AM
Many thanks! Mission accomplished.
Old Apr 17, 2012 | 09:15 AM
Tech Guru
Tech Guru
You're welcome.
Johann2.7t
Dec 17, 2010 10:22 AM
computrtutr
Aug 2, 2008 09:01 PM
baudenfj
Dec 31, 2005 07:03 AM
boxerfan
May 5, 2005 06:20 AM
Audi baby yea!
Apr 23, 2004 07:19 PM
