Secondary Air Injection
Old Apr 16, 2012 | 08:45 PM
Jac92071's Avatar
Default Secondary Air Injection
I have a 2000 A6 2.7t with a secondary air injection low flow code for both banks. The information I got from Alldata says to check the fuse and relay and they are located on the fuse panel in the E-box plenum chamber but I have no idea where that is. Can anyone give me a hand with this.
Old Apr 16, 2012 | 10:20 PM
OGBULLYLOCDAWG's Avatar
It's located behind the knee bolster on the drivers side.
Originally Posted by OGBULLYLOCDAWG
IIRC there are 5(8mm) bolts, 2 on the bottom, one through the side where the fuse are located and two more up by the steering column (you will have to remove the plastic between the steering wheel & cluster to expose those).
(photos courtesy of gpsmagazine)
IGNORE THE CIRCLED AREA!
The two 8mm bolts I'm referring to, are to the left and right of the steering wheel on the lower portion of the bottom photo.
Ckplaner77
Jun 17, 2019 10:01 AM
OzzyLime
Nov 23, 2011 05:45 PM
jschick
Apr 20, 2011 02:48 PM
Panzer A4
Jun 9, 2009 05:48 PM
Decolliber
Audi 100 / A6 (C4 Platform)
Jan 7, 2004 10:20 AM
