Tt 180 roadster transmission compatibility
When I separated the axle from the flange I noticed the flange was full of gasket maker... I was pissed when I saw this, I took all the gunk out to access the bolt. the bolt is not the original so got even more pissed. I start to take the bolt out and I notice the bolt was cross threaded all of a sudden it just starts to spin but I can feel its grinding on something after fighting for several hours I decided to cut the bolt out and i got the flange out. After inquiring with different transmission shop the say the transmission is pretty much gone and I need to do a complete rebuild, which I don't believe the car was shifting perfect before all this. Then I had the bright idea to just do a transmission swap.... So when I do research on this I find the transmission code needs to be egz and I confirmed with the Audi dealer using the vin... Well what is on the car is not an Audi transmission, the code is egx and Audi dose not have this code so obviously it's a vw transmission now the question is what transmissions are compatible with Audi tt trany? I have found several transmissions that say they are compatible with egx. And I have found some that are even 6 speed that are compatible with egx but I weary of buying something that won't work and get stuck with a large paper weight ... Need help please advise on possible solutions.
If egx is compatible with egz, And (X) is compatible with egx, is (X) compatible with egz?
