rear backing plate
My rear backing plate , driver' side, is so rusty I've surmissed that it's triggering my ABS and ESP to turn of. In order to replace, it appears I'll need to remove the hub and attached tuning ring. Once the shaft nut is removed will the hub just slide off with the bearing and race inside? I haven't found anyones eperience withthis in a "search" but would love some advice before digging in
Thanks
Jeff
