Convertible roof light indicator on when roof it up
Old Apr 28, 2012 | 07:38 AM
lawnerd's Avatar
Default Convertible roof light indicator on when roof it up
Hi. Anyone else ever have this problem. The dash light that indicates that the convertible roof is being opened is on even though the roof is up and latched?
It started when I put a large package in the passenger seat that may have bumped the top of the roof when I was putting it in the car.
Any ideas on fixes?
Old Apr 29, 2012 | 03:34 AM
lawnerd's Avatar
Default Problem identified!
OK. Looks like my problem is the switch which is located on the top of the windshield on the driver's side. When you latch the roof shut the catch on the roof pushes the switch and turns off the dummy light. My switch is either bent or worn so that it is no longer pushed by the catch.
For now I put a piece of aluminum foil on the switch. But I think I might try to reposition it using a small screwdriver.
Anyone else ever have this problem?
Old Jul 31, 2012 | 06:09 PM
Lexx's Avatar
Default old thread I know.. but same problem.. couple pieces of electrical tape......
have lasted years on our car. Probably can move the switch..or replace it. But tape is free..and been working fine
Old Aug 1, 2012 | 11:58 PM
TaciTrequiem's Avatar
I am having the same problem now, can you describe how you applied the electrical tape fix?
Old Aug 5, 2012 | 06:19 PM
lawnerd's Avatar
I had the same problem. The issue is the switch on the drivers side, where the roof catches. You can try bending the switch with a screwdriver. However, this is what i did. I had one of these new hooks that attaches to a wall or door. It comes with a thick pad with adhesive on one end. I cut this pad to size and attached it to the switch with adhesive. It made the switch thicker, and thus activated when the roof was latched. Problem solved.
Old Aug 6, 2012 | 03:57 PM
Lexx's Avatar
Default apply it to the switch where the top hits the latch from the top. gives it just ....
enough thickness to shut off the light.
look on the drivers side area on the windshield frame, you will see a switch. just put a piece or 2 or 3 of tape on the switch
RedAudiTT
10
Aug 9, 2004 10:19 AM
AlanBDahl
Jul 20, 2004 08:38 AM
germinator
Dec 3, 2002 01:55 PM
marcogyver
Audi 100 / A6 (C4 Platform)
Oct 22, 2002 06:26 PM
Tom Faust
Sep 24, 2001 09:12 AM
