Is '02 A6 a money pit?
The question I have is is this car going to be a money pit? I read a lot of anecdotal stories online about people needing to spend a lot of money on repair and maintenance just to keep these going after 100K miles. I asked my mechanic, and he seemed to think that the repair cost was on par with an 02 VW Passat AWD, which is the other car I'm considering. But I figured there were probably a lot of people in here who had experience with this car. I'm not made of money and will feel pretty stupid if I have to sink thousands a year into it just to keep it running.
bottom line, cars are expensive to maintaine, older cars over 100K can be a money pit no matter what make or model, it all depend on how htey were cared for,
do regular scheduled maintaincence and put 50-100 dollars away per month on top of that, use that as your repair fund. if you can afford to put 50-100 away per month on a repair fund, you shouldn't be driving
The oil changes are crucial. If the owner cannot provide the oil changes or hints he does cheap oil changes at places such as jiffy lube avoid. With 90k you should ask if the Timing belt was changed. The manual and the dealership say 105k but as a precautionary measurement people here change it early at around 89-95k. There are some that change them as early as 60k.
This car will REQUIRE PREMIUM fuel. If you cannot afford to pay 5 dollars more at the pump for a full tank for premium, look for something else. Even the passat requires premium if i recall.
I would recommend you get the price of the car cut about 1500 and use that money to do timing belt and a major tuneup.
When replace the serp spin the various idler pulleys and consider replacing them if they're wobbly or noisy or feel notch but otherwise just leave them alone.
Chances are the owner didn't want to pay to replace the TB, due at 105K miles for the 2.7T. Factor in the TB service ($500 parts plus $$labor if you can't do it yourself) in the price.
Basically, it sounds like the guy is asking $1500 too much.
