HP-2 Caliper Guid Pin Boot...?
Old May 1, 2012 | 02:31 AM
tester123's Avatar
Default HP-2 Caliper Guid Pin Boot...?
Changing brake pads realized uneven wear on passenger side caliper. Turns out that caliper's floating frame is stuck due to rust inside. Was able to loosen it finally and cleaned it up but noticed the boot is in real bad shape.
I searched the forum but not much luck. Does anyone know where the boot could be found?
If so, please let me know.
Below is exactly the picture of what I am looking for.
(credit:FAN OF F1)
Also, that thread indicates using a boot from mountain bike...
https://www.audiworld.com/forums/sho....php?t=1725859
Any better solution than that?
Old May 1, 2012 | 04:35 AM
Just Me's Avatar
Tech Guru
Tech Guru
i have never seen them. I will say that i just bought a NuGeon rebuilt HP2 and it is gorgeous, contrary to most rebuilt crud.
G
Old May 1, 2012 | 06:34 AM
SloopJohnB@mac.com's Avatar
Tech Guru
Tech Guru
If you cannot get a new boot use the mountain bike boot or just clean your existing boot very well with a non-greasy cleaner like a carb cleaner and then use black silicone RTV to repair any tears in the boot.
Bubuski
May 13, 2005 09:13 PM
