Engine won't shut off
This has happened a few times now and I figure I should address it before it's too late.
I'll drive a short trip, stop, put the car in park, turn the key to the off position and remove the key but the engine will continue to run!
The only way I've been able to shut it off is hitting the brake pedal a few times or taking the car out of park.
Any suggestions on what to look into?
I replaced the ignition switch with an new OEM switch. The problem has reoccured twice since then.
Is there an ignition relay that could be sticking closed??
Both times that it happened I had removed the key and the engine stayed on along with the cluster being on too. I was able to turn off the engine by pressing the brake pedal for 5 seconds.
Fingers crossed again.
Turn the ignition Off, the radio goes off. In most other cars it keeps playing as long as the key is in the ACC position.
But damn if turning te ignition off cuts off my vanity mirror light! How else am I supposed to pick my teeth or put eye liner on?
