'01 2.7 alternator almost dead
Once out does it make any sense to attempt a partial rebuild? I've found a Regulator/Brush Assembly for $39 from aspwholesale.com. An entire rebuilt unit is $250 on-line. Many thanks...
If the slip rings haven't been damaged due to arcing you can just replace the v/r and brush assembly. IMHO the brushes should be replaced every 140K miles on GP, but the brushes often can't be replaced alone on these alternators...you have to look at the v/r and see if they're soldered in...spot welded is a deal breaker unless you have the spot welding equipment. I have a mig welder but didn't even try to use an electrode to spot weld much less source the pigtailed brushes (Bosch had them for my last alternator brush replacement on a volvo 740T).
Theoretically I could remove the alternator on my 2K4.2A6 without service position but I found it much easier to collapse and hold the tensioner as well as remove the long mounting bolt with the service position. The alternator on the 4.2 is on the bottom right of the engine and drops right out once the serp belt is off. The 2.7 has a different mounting position.
The USUAL cause of the air raid siren is the primary fan (on the engine side of the radiator assembly) jamming and burning up the controller. Because of the reduced cooling capacity, the secondary fan runs full speed whenever the A/C is enabled.
There is a piece of rubber trim that jams the blades of the primary fan. I had the exact symptoms listed in the write-up and the cure was exactly as written. Remove the jam and replace the controller. All was 100% good after that, as the high dollar component (controller) failed and protected the low dollar component (fan).
It's much easier to replace the controller in service position, and yes, the controller is expensive.
$250 seems a little steep.
I did bearing, rec and brushes for less than $90 (all it needed was the front bearing and brushes).
Then I'm **** when it's spread in front of me on the bench and all that's needed is parts.
If it to spins, forego bearings and if the brushes are used up replace them as the rec/voltage controller (very) rarely go away.
New battery is a nice touch if the old one is 5 or so years old btw.
pc
