NEED HELP! '00 TT w/ severe electrical issues after disconnected battery
Old May 22, 2012 | 08:44 PM
RWDsnail's Avatar
Default NEED HELP! '00 TT w/ severe electrical issues after disconnected battery
I have a 2000 Audi TT. Over the weekend I did my best to completely degrease the engine bay.... while I was in there I noticed a plug with four wires attached (by the driver side headlight) that was not connected to anything.. so I took out the battery to have more room and get a closer look. The battery stayed out of the car overnight, as I wanted to clean up the engine bay more the next day and had more access with the battery out in that certain area.
1.) I degreased and hosed down the engine bay
2.) Battery was disconnected from the car overnight
TWO days after the battery was put back in and driving the car, the car suddenly develops electrical issues.
Issues:
1.) passenger headlight flickers
2.) both windows are extremely slow at going up and down
3.) aftermarket radio no longer works, but flickers lights on its face
4.) odometer needle is inaccurate, will stick at 60mph no matter the speed
5.) temp gauge reads 3/4 when car has been sitting for hours
6.) A/C doesnt work
7.) When A/C is "on", headlights wont stay on, dash lights go off
8.) Car needs a jump start if its been turned off.
etc...
What can I do to fix this? Is this all because of the main fuse? Did I blow something? I don't know where to start, and am looking for help!
Any help or advice is appreciated!!! I'd like more intel onto what happened to cause all these problems and what I need to do to fix it. Thanks!
Old May 23, 2012 | 03:20 AM
RWDsnail's Avatar
Nobody?
Old May 24, 2012 | 06:48 AM
audiqv8's Avatar
Either you didn't tighten the battery connection or the terminals have corrosion and needs cleaning. Since this is a battery related issue go back and check everything. You might also want to check the alternator since it sounds as though it might not be charging your battery.
Old May 26, 2012 | 06:53 AM
Jdaniel343's Avatar
Default Electrical issues
You could have possibly gotten water in connectors that were not totaly sealed.
I would probably check the battery connection first. Clean battery terminals and cables.
Look for electrical connections, seperate the connectors, spray some WD40 on the connectors and reconnect. Do this for all the connectors you can find and get too.
Good luck
Daniel Monsi
Dec 11, 2017 09:34 AM
P
Dec 24, 2010 02:47 PM
EasTTcoasTT
Oct 6, 2003 07:51 AM
brickz_TT
Mar 2, 2003 09:54 AM
gtt
Sep 8, 2002 10:50 AM
