Checking fuel delivery system 2001 TT 6-speed
Old May 23, 2012 | 11:12 AM
Jpollock's Avatar
Default Checking fuel delivery system 2001 TT 6-speed
The car wouldn't start. There are no codes. To check for fuel delivery I pulled the module off at the end of the fuel rail (right side looking into engine). One question would be, do I expect fuel to flood out at this point when I turn the car over? There was no fuel. Assuming there should be, I checked power at the fuel pump fuse. Without diagrams, I assume that when I crank the engine I should see power here if the relay is working. Does this logic sound correct? There was power so I assume power to the relay coil and to the pump.
I'd like to check the connector to the pump before I assume the pump is bad. Does anyone have an idea if that connector is accessible through the trunk?
The car died too easily in my opinion. I pulled it out of the garage, washed it, pulled it in dried it. Then when I went to start it up an hour later, it wouldnt start. This is why I'd like to follow the electrical path first.
Thanks for any help anyone can offer.
John
jschick
Jul 15, 2013 05:55 AM
RA060624
Jun 6, 2012 12:58 AM
ggjoy
Apr 22, 2012 02:17 PM
casem
9
Jul 29, 2007 10:09 AM
dirtyhands
Audi 100 / A6 (C4 Platform)
10
Sep 27, 2005 02:26 PM
