Slowly keeps going into limp mode Bank 1 too lean
I had this same problem. I had checked all of my visible hoses as well and found nothing. I had a smoke test done after having no other options and found the leak under the manifold front passenger side of the car. There are a few tiny vacuum hoses under there that are exposed to a ton of heat and the ends get dry and crack. The hose for replacement has to be purchased from Audi, but is only $8.00 per meter which is more than enough. You can try and use either propane or carb cleaner to find the leak. If it gets into the system the car will idle way down or shut off and then you can narrow down the location.
Good Luck!
