audi 90 cluster odometer stoped working
Old Oct 15, 2012 | 05:37 AM
apirpiris's Avatar
Default audi 90 cluster odometer stoped working
Hi. I recently needed to install a new ignition on my 94 audi 90 v6. Upon reinstalling the cluster my mileage calculator is not working on top or bottom.
Everything else the cluster works including speedometer/tach. I see no bent pins in the cables. I have never had an issue prior to this. Is there a procedure I am not familiar with when reinstalling a cluster?
Any thoughts would be greatly appreciated!
Old Oct 15, 2012 | 07:37 AM
CRAZY_RUSSIAN's Avatar
STFA, there is plenty of info on that
Old Oct 15, 2012 | 09:33 AM
apirpiris's Avatar
While I appreciate the sarchaism I have already searched for countless days. All of the archives speak of this issue stemming from a malfunctioning speedometer which I do not have.
IF you find the link you would be doing me and my 70yr old father an awesome audi favor.
Old Oct 15, 2012 | 09:37 AM
Audicted's Avatar
Either you did not push the connectors on the cluster tight enough or you have a broken odometer gear. The way to fix the gear and the source for the parts are here: http://audi.humanspeakers.com/odometer.htm
Done it many times, on a scale of 1-10 it's a 6.
Old Oct 15, 2012 | 10:00 AM
apirpiris's Avatar
I already opened the cluster. Turned the gear almost 3 miles with no problem. I was going to put the car on the lift and maybe start shaking the harness as a last attempt.
My buddy at the dealership told me to drive it with no odometer.... not the answer I was looking for.
Old Oct 15, 2012 | 02:27 PM
that wasn't sarcasm man, re-solder all the points on the cluster, after 20 years, they do brake
therichisgood
Jun 11, 2013 03:25 PM
JessicaK
9
Jan 12, 2011 09:42 PM
prijedor
Aug 31, 2008 07:09 PM
RedBlackYellow
Jan 30, 2007 10:38 AM
selfproclaimedv8buff
Mar 8, 2002 08:59 PM
