95 90 Q 2.8 running rich?
Old Oct 31, 2012 | 03:52 PM
duanevw's Avatar
Default 95 90 Q 2.8 running rich?
Its been a while but I noticed my 95' 90 Quattro 2.8l running a little rough under load, Rich running, tail pipes are cartoned up no check engine light. Has a slightly hesitation when accelerate on Gas.
I want to say the Coolant Temp sensor to the ECU, Im not quite sure if this ecu picks that up as a code for this year. Its been backfiring when I let off the gas underload only.
Any ideas, has new plugs 4k miles ago, no oil leaks or coolant leaks,
Thanks Duane, MI
Old Nov 1, 2012 | 03:26 PM
Loudgoldwing's Avatar
I would say a catalytic converter is clogged.
Old Nov 2, 2012 | 01:58 PM
duanevw's Avatar
I will check for any vacuum leaks and coolant temp sensor, because it seemed to happen quickly not over time since.
Thanks Loudgoldwing
bendiksandoey
9
Apr 17, 2017 11:32 AM
danfil
Oct 27, 2015 10:20 PM
OzzyLime
Sep 17, 2015 06:19 AM
texasaggie2011
Sep 14, 2015 05:39 AM
gagethrash
Q5/SQ5 MKI (8R) Discussion
Sep 8, 2015 07:11 PM
