Exhaust Leak
Just as unfortunate is the fact that, for a pipe to corrode enough to split where it did, there's no way to fill it with a welder. The surrounding metal is probably paper-thin.
Right there is where you get the most torsion in your exhaust system from accel and decel. It has to be solid. It can't be repaired. It must be replaced.
you probably shouldn't get used to it :-P
