Driveshaft romoval help
Old Dec 4, 2012 | 02:31 PM
93CSQ's Avatar
Default Driveshaft romoval help
Ok, so I found out that I may be needing to replace the RMS soon, and I may be pulling the transmission with the help of these:
My problem is that they say to use an Audi special tool that attaches to the drive shaft in order to keep it in alignment.
Has anyone removed the driveshaft and if so, did you have any difficulties?
TIA
Darwin
Old Dec 4, 2012 | 05:42 PM
Lago Blue's Avatar
Default This description may help you sir...
I have not done this job, however this thorough sounding write-up which mentions the "special tool" may help put you at ease. See under "R & R".
http://20v.org/drvshaft.htm
Hth
Lago
Old Dec 16, 2012 | 01:33 PM
4AudiQ's Avatar
TIA
Darwin
I have.
I took a picture under the car, but I can't seem to get the picture uploaded. So, go to Photo Bucket & search for 4AudiQ and that picture is at the very bottom.
Here is my make-shift drive shaft support mechanism. The factory suggests you lower the drive shaft as 1 piece with some kind of support underneath it. Of course, they were not expecting us to replace their design with a better design, so they expected us DIY’ers to put the 2 piece drive shaft back in place.
Old Feb 15, 2013 | 05:59 AM
Huskerbob's Avatar
Default Driveshaft alignment
Originally Posted by 4AudiQ
I have.
I just replaced the driveshaft on my A4 Quattro Avant and would like to see that photo you took of yours. I can't find it on photobucket.
Did you by chance use a one piece replacement? I'm looking at that since my new one as a bit of a moaning noise every now and then. Thanks.
Chicago Discussion
Mar 17, 2008 02:21 PM
T-dot B6
Canadian Discussion
Mar 19, 2006 04:49 PM
83UR-Dont-run
Sep 26, 2004 07:55 AM
eyeman
Feb 5, 2003 06:10 AM
