'93 Audi 90 CS Quattro Speedo/Odometer Issues
Old Dec 12, 2012 | 08:05 AM
Dino V's Avatar
Default '93 Audi 90 CS Quattro Speedo/Odometer Issues
Hoping someone has a bit more knowledge on this issue.
Everything works on the gauge except the speedometer and odometer. But if I am on the highway at a consistent speed, the speedometer starts to erratically jump from 10mph-80 mph, with sometimes staying at correct speed for a few seconds before it starts to make the erratic motion again. During this time, the odometer also works. Once the speedometer stops working and consistently over 3000rpm the check engine light comes on, then turns off the moment the speedo needle makes any slight movement.
I have also noticed that the speedo/odometer tends to try to operate more often when the weather is cold out (I assume this is due to increased amps/resistance/etc associated with colder weather).
Anyone know what this might be? I greatly appreciate any advice.
Thanks,
Dino
Old Dec 12, 2012 | 08:56 AM
CRAZY_RUSSIAN's Avatar
that sounds like a bad connection somewhere, but what i would do first is take the cluster out, clean all the connections and re-solder everything on the cluster. ive head a problem of my odometer randomly working/not working, partially working. re-soldered the cluster, problem fixed ;-) give that a shot, its an easy job
Old Dec 12, 2012 | 09:44 AM
Dino V's Avatar
Thanks buddy, I will try it as soon as I get a chance and hopefully it fixes it.
Aintscared35
Jun 24, 2018 05:21 PM
200tqdan
Feb 1, 2009 04:56 PM
Audi_ibuA
Oct 5, 2008 01:10 AM
RCOOMBS
12
Sep 12, 2005 02:02 PM
design89
12v V6 Discussion
Jan 26, 2005 07:33 AM
