head lights dim
Old Jan 22, 2013 | 02:40 AM
royemello's Avatar
Default head lights dim
alt has good output - 13.2 - but headlights dim @ idle
good battery
1990 audi 90 aah eng
do these cars have a ground issue ?
thanks R.
Old Jan 22, 2013 | 02:51 AM
audi01a6's Avatar
good battery
thanks R.
hey ROY,ck the grounds at the headlights,see if they r clean,
Old Feb 20, 2013 | 04:03 PM
roadcommander's Avatar
good battery
thanks R.
If your alt was strong you would be getting closer to 14amp, I have intermittent charging system problems even after putting in a new alt. I would suggest a grounding kit im putting one on mine right away, also due to the location of your alt any oil leaks on that side of the engine seem to always dip down onto the heat shield then onto the alt, if you have any oil leaking thats getting on to your alt, I would suggest spraying down your alt with some brake cleaner, if your alt is running a little weak cause of oil getting in there that should bring it back up to 14amp ( temporary) and your lights should start working better. If you do have a leak fix it asap it will eventually kill your alt
adanow
Q5/SQ5 MKI (8R) Discussion
9
Apr 30, 2018 08:52 AM
nyrobbie77
Nov 18, 2015 01:33 PM
audi-bahston
Jun 11, 2007 09:52 AM
BMason_jr
May 11, 2003 01:06 PM
crazyhomer
Aug 30, 2002 12:39 PM
