PS Rack Seal. Forum Newbe
Old Feb 23, 2013 | 09:35 PM
kennedyanyanwu's Avatar
Default PS Rack Seal. Forum Newbe
Kennedy From Nashville TN here, Hello
I have a question about the PS rack on my Audi. Ive had to rebuild my PS rack twice b/c the rotary valve housing seal keeps blowing out (seal for the steering input shaft into the rack). I rebuilt it the first time bc I had the engine out for a rebuild and I knew the tube seal (tube connecting to the tierods) was leaking a bit, so it seemed like a good idea with all the available room. After the first rebuild with a rack seal kit I got online, there was some noise from the rack i couldnt get rid of despite all the bleeding I did. there was no air bubbles in the fluid bottle but it sounded like trapped are in the rack even though the steering turned smoothly. I figured after some time it would stop but it didnt. after about a month the rotary valve seal blow out while the car was warming up (shoes, pants, pedals and carpet soaked in PS fluid). So I got another seal kit from a different source and did it again and behold after a month it happened again.
Iv read the rebuild procedure over and over on Alldata at work and theres nothing that stands out as far as what Im doing wrong.
Id like your opinion on what else I can try as far as process or part source.
thanks.
Old Feb 24, 2013 | 07:18 AM
CRAZY_RUSSIAN's Avatar
what fluid are you using?
Old Feb 24, 2013 | 10:39 AM
yodasfro's Avatar
Has the pump ever been replaced? Perhaps it's the wrong one putting out too much pressure? This may help http://www.s2forum.com/forum/showthread.php?t=25808
Old Feb 24, 2013 | 07:29 PM
I put some off the shelf generic fluid both times(auto zone). including a little stop leak for precaution before the blow out. now that u mention, it may b worth looking into.
Old Feb 24, 2013 | 07:31 PM
I never replaced the pump and iv owned it 6+years 3rd owner. plus it never had this issuer before i rebuilt the rack.
The_Hamster
May 22, 2008 03:56 PM
Biscuit141
Audi 100 / A6 (C4 Platform)
Nov 1, 2007 08:15 PM
TMF5000QT
Aug 5, 2006 03:36 PM
MikeB490
Nov 28, 2005 02:04 PM
audiA6GT
May 27, 2005 04:48 PM
