G60 brake swap, 4 to 4 lug needed?
"Front - 304x32mm
Front Rotor - 8A0615301B(L) 8A0615302B(R) [ 965-351-041-01(Mono) 965-351-042-01 (Drilled) ]
Pad Damper - 8A0615231D x4
Front Pad - 8A0698151F [ 993-351-939-01 ]
Repair Kit - 8A0698430, 8A0698430A
Rear - 299x24mm
Rear Rotor - 8A0615601C(L/R) [965-351-041-01(Mono) 965-351-042-01 (Drilled) ]
Pad Damper - 8A0615231B x4
Rear Pad - 8A0698451A [965-352-939-04]
Repair Kit - 8A06986308, A0698630A"
Check this out, set of front brakes to your Audi http://allegro.pl/audi-s2-zaciski-ha...045849519.html
Then tech articles.
Then tires/brakes/Susp.
Then 80/90.
Then Porsches brakes.
You will find the info you need to make your own front brake upgrade.
Greg W.
