Radiator fan not working - suggestions?
http://www.sjmautotechnik.com/troubl...oling.html#fan
The plug on the fan itself should be checked too as over time the female connector can become loose breaking the connection inside the fan.
As for coolant, I flushed out the smaller secondary radiator while I had the bumper off by repeatedly reversing full hose flow and only after about 8 cycles did the water stop coming out with some crud. So the main radiator is doubtless in need of the same treatment as is the heater core. Fresh water pump. Fresh corrrect thermostat and O ring.
Anyone know of a coolant system flow diagram so I can pull the correct hoses off to reverse flush the radiator and the heater core? Thanks.
DougM
I tested mine by using an ohmmeter and putting it in a pot of boiling water.
