Please read. I need help
If this stuff worked, the seller would have been able to get 3-4X more for it.
You got a lot of help here back in January.
Did you replace the ignition switch and trunk wiring like you were advised to then?
If you successfully replaced the heater core yourself, then it shows you know your way around a car, that's not a job for the faint of heart.
If you paid someone else to do it, then it shows you are smart enough to avoid that horrible job.
In any case, most, if not all, of this stuff can be found by searching the archives:
https://forums.audiworld.com/search.php
http://forums.quattroworld.com/oldsearch/
http://www.12v.org/engine/index.php?section=cl&view=oil
http://www.motorgeek.com/index.php
http://www.s2-audi.co.uk/technical.htm
And there's many more sites beyond these; Use the Search, Luke.
There's no way I'm going to try to process that novel you wrote.
Keep your questions simple and to the point and you might get more help.
And remember, must of us are not professional mechanics and the advice you get here may be only worth what you paid for it.
So, replace the ignition switch, fix the trunk wiring, then prioritize your problems, from most critical to least, and start researching and fixing them one-by-one.
For the safety related ones, such as the antilock, pay someone to fix them if necessary. Right now, 80% of the cars in front of you, whose anti-lock systems are working, can stop faster than you can and if you get into a chair-reaction braking situation, you are going to end up paying for their wrecked rear bumpers and junking your wrecked Audi.
Thanks for your input: A corporate phrase that could either mean "thanks for your input", or, more cheerfully, "f*ck you!"</font>
Sometimes I wonder why I bother....
Have fun!
Have fun!
