Suggestions for bushing kit for 1990 90 suspension?
DougM
http://www.s2-audi.co.uk/technical.htm When I did mine I got them from rockauto for a decent price. The fronts are a little pricy for the lemforder's but you don't want to have do the job twice.
Thanks. And thanks for the tip on that UK technique for using threaded rod and pipe caps to do this work. I'm thinking I may be able to lay under the car and do these right on the car, though the UK site shows the control arms on a workbench.
DougM
forged(late build) the latter uses the larger bushings. You'll want to do it on the workbench in a vice. The best method for removing the old bushings involves a hack saw. I've never had much luck getting the bushings to press out.
I will let you know how the threaded rod press works out. If it does not, I will turn tail and run to a place with a 20 ton press I've been given access to once in a while. I'm just hoping I can avoid taking off the lower arms, and just do it laying under the Quattro. One trick on that threaded rod trick is to lube the threads of the rod so you are not fighting friction and more easily converting turning torque into power.
DougM
