Injector retrofit, Hesitation and exhaust smells
Has anybody else done this injector retrofit and had any similar issues.
DougM
So, something is up, but if my experience is any indicator, it is not the injectors. Does your tech really know this EFI system? I'm going to speculate not, because those are serious operating deficiencies, and him wondering if these injectors are "programmable" tells me he is not particularly well qualified to work on this system - a very basic EFI system by the way.
DougM
DougM
Another thought was maybe my catalytic converter(looks like the original) was bad and maybe i'm building to much back pressure, so I took it to my muffler guy, who just so happens is a big Audi enthusiast. He doesn't think my cat is bad but agreed the fuel mixture out the pipe was to rich. We may run a back pressure test to confirm this.
You are probably right about the injectors not being the problem but something else. Maybe intake manifold pressure, MAF sensor (I did check it when I changed the air filter and it was clear),fuel pressure at the regulator.
it just is weird that all runs okay until you hit that 3500 rpm. then it goes to poop!
Mike in Casper
I used to have an old AMG ML55 that had this same issue. It turned out that the problem was a failure of the changeover solenoid that was supposed to switch the position of a flap in the intake. At 3300 RPM, the vacuum-actuated solenoid would clode a little trap-door in the intake manifold. The closure of that trap-door shortened the airflow pattern in the intake and gave you a bump in hi-end grunt.
My changeover solenoid wasn't closing that trap door all the way, and the resulting airflow pattern in the intake was kind of a combustion chaos. This in turn threw the burn balance out of wack, started telling sensors that the fuel-air mix was wrong... just not a pretty picture at all.
On the advice of a friend, I pulled the solenoid because it was easy to get to on top of the engine. Guys, it was NASTY-caked with carbon on the inside, AND had a cracked vac line leading up to it, as well (my buddy said the cracked vac line allowed dirt into the solenoid, and the heat of the engine baked it on to the inner surface. REALLY smart guy).
I soaked the solenoid's internals with carb cleaner, blew it out with compressed air, soaked it again with some WD-40 and drained it. Replaced the vac line, reinstalled.
Never gave me an issue again for the next 10,000 miles I owned it.
Like I said, I don't want come off like a know-it-all, here. Your engine might be configured way fifferent than what I'm used to in the 12V. But your issue seems to hit a little too close for me to just leave you hanging, ya know?
Good luck, and let me know how it goes, please.
Or, you could also go look at the following location I found for the part I'm talking about (which I'm now fairly CERTAIN is your issue):
It's located right near the MAF. It has 2 vacuum lines going into it and a plastic cap on one end. It's about the size of a 9V battery.
It has a vacuum leak, dude. Probably happened when you pulled the MAF to clean it. When the secondary fuel dump kicks in, the intake airflow path needs to shorten in order to compensate. If you have a vacuum leak at the changeover valve, the changeover itself won't happen, and your exhaust will stink with no power.
Somebody please either verify my line of thought or just tell me to shut the Hell up. You're killing me right now.
