What's your shift pattern? Is my clutch okay?
Old May 3, 2013 | 07:06 PM
wyoaudidude's Avatar
Default What's your shift pattern? Is my clutch okay?
I'm curious about a good shift pattern for my 7A 20 valver. I drive pretty conservative shifting under normal accelleration between 3000-3500rpm......should I rev it higher? Is it correct that the 7A's are not speed burners off the line? normal acceleration you seem to have to get on it to get speed up,.....not a lot of torque at the low gears...except when you floor it! I'm inquiring because I've never had a 20 valver till now. I was told that my clutch "might" be on it's way out...,it's not slipping, that I can tell, but it is at the top of pedal. My mechanic told me it should be pulling harder on acceleration. The engine/clutch have 164K. The car does runs fantastic! It runs about 3000rpm/65mph....is that about right? Blah,blah,blah!! LOL
Old May 5, 2013 | 08:41 AM
Anybody?
Old May 5, 2013 | 09:15 AM
yodasfro's Avatar
You would know if your clutch was bad. I don't think you have anything to worry about. Yes these motors need to be wound out to really get going.
Kingttr
Apr 23, 2007 01:48 PM
AJN334
21
Dec 7, 2004 04:26 AM
LUCIFA
19
Jan 6, 2002 09:14 PM
Audiphile64
Sep 19, 2001 07:09 AM
audidood
May 31, 2001 01:45 PM
