Oil burning issue. It's a bit different though..
Car fouls cyl 6 plug every summer, maybe two if I use it a lot. Always fouls on a down hill section when resting at a stop light or stop sign. Always. Always smokes more when taking off from a down hill resting spot like a stop light. Smokes less or none when on flat land.
Also smokes when accelerating around a very hard left hand turn.
Valve seals? Scored cyl walls? Either of those two, though I don't know how it would smoke more, and dump more oil in the cyl going downhill or around tight turns.
Thoughts anyone? I know PCV systems have been known to cause oil consumption, would it cause back pressure into the case and cause any of these related issues?
I do still need to boroscope cyl 6 and see if the walls are scored.
