1997 A6: Wipers move, no washer fluid!?!?
Old Jul 19, 2014 | 06:53 PM
AudiC4HighExplosives's Avatar
Default 1997 A6: Wipers move, no washer fluid!?!?
I just bought a 1997 A6 sedan for my DD. The wipers work, but the fluid for the windshield and the headlights does not come out. The 13 slot fuse is fine. I do not hear any pumps when lever is pulled. Is it the pumps plural or a relay? thanks! Glad to be driving a c4 again. Used to own an s6 wagon.
Old Jul 21, 2014 | 04:29 PM
Is everyone on here a mechanic noob like myself? Where is the reply telling me what to do next??? Check a relay, test the pumps, common! I joined this club because i like audi's and could use some guidance.
Old Jul 22, 2014 | 07:20 AM
Rusty Spokes's Avatar
If the car has been sitting for a while and the washer pumps have not been used..the washer bottle can collect algae.
Take a look under the car drivers side and you will see the washer bottle and the pump. (you may need to remove the fender wheel well cover)
See if you are getting power to the pump when the washer lever is engaged (it takes a buddy to help), check the ground side brown wire too for good ground.
If you have power and a good ground..the pump may be dead or the washer bottle full of algae..pull the pump and inspect the bottle (flush it out if you see lots of junk). Power up the pump on the bench/under the car to test.
If you need a new washer pump they can be had very inexpensively from the usual on-line vendors.
This forum is very silent..don't know why.
Old Jul 22, 2014 | 04:29 PM
Thanks for the insight. I will get it up on jacks this weekend.
Old Jul 22, 2014 | 06:30 PM
egp320i's Avatar
Banned
What Rusty said, and/or the pump just simply failed which can happen depending on how often they were used.
Bear in mind the headlight washers only spray with your headlights on. [headlights are generally on in winter when the lenses are being caked with salt/road flack]
Old Jul 23, 2014 | 03:32 PM
With the headlights on, neither work...
Old Jul 24, 2014 | 05:44 PM
egp320i's Avatar
Banned
Last I recall the headlight washers have their own pump from the windshield.
Sound like either the pumps are dead or there is a wiring issue.
Groosh
Dec 21, 2018 05:24 AM
Harleyguy
Feb 15, 2017 01:02 PM
NeverSummer-ver. 4.2
Mar 16, 2009 07:22 AM
Willfulone
Jan 21, 2005 08:53 AM
skategoat25
Audi allroad
Apr 25, 2003 05:10 AM
