Cylinder Numbering Question
I was wondering if perhaps I'm looking at this wrong or if there's some other issue here. The cylinder numbering is 1234 on the passenger side with 1 closer to the front of the car and 5678 on the driver side with 5 closer to the front of the car. Is this correct?
Front of car passenger side | 1 2 3 4 | Back of car
Front of car driver side | 5 6 7 8 | Back of car
My confusion was created because this engine is timed off of cylinder TWO not cylinder one like most engines. When the crank lock pin (crank holding pin depending who you talk to) is installed cylinder TWO should be at TDC (Top Dead Center).
