Differentials
Quattro (four-wheel-drive system) - Wikipedia, the free encyclopedia
So the TT has four wheel drive with brake actuated torque vectoring? How does that compare in regards to corner traction? I'm coming from a mazda mx5 with the same EDL but I think it's only the rear wheels that have it.
The new RS3 I believe has torque vectoring along with a much more rear-biased tuning of the Haldex system.
The latest generation system in the current TT is more proactive and it shifts torque to the rear axle under acceleration and cornering, but never more than 50%. The previous generation systems were reactive and only shifted torque to the rear axle if the front lost traction.
The Haldex system is often criticized for being essentially a FWD drivetrain until the front axle looses traction and then it calls up help from the rear axle, but as I said this is no longer true in the latest gen system. It makes more use of the rear axle, but it's still very front-biased.
If handling is important to you I would look at the TTS as Audi tunes the Haldex system more aggressively in the S and RS versions.
