S4 (B6 & B7 Platforms) Discussion Discussion forum for the B6 Audi S4 produced from 2003-2005 And B7 Audi S4 produced from 2005 -2008
Coolant temp sensor settin CEL every month
Old Jan 23, 2015 | 04:37 AM
ajg617's Avatar
Audiworld Senior Member
Default Sorry - meant to post in the a4 B6 forum. Coolant temp sensor settin CEL every month
This is getting stale (earlier post on 6/27/14). Replaced the CTS around August in my wife's 05 B6 3.0 because after sitting out in rain, the CEL would randomly come on (along with a few misfire or fuel related codes and a brake vacuum boost code). Audi had the car in mid December and replaced the Brake Boost Vacuum pump, a relay, and a leaky vacuum hose. Last night, CEL pops on again with the following codes (I've seen this set of three before but always the P0118 sets the CEL):
17537 - Fuel Trim; Bank 2 (Mult)
P1129 - 002 - System too Rich - Intermittent
16559 - Fuel Trim; Bank 2
P0175 - 002 - System Too Rich - Intermittent
16502 - Engine Coolant Temp. Sensor (G62)
P0118 - 002 - Signal too High - MIL ON
Readiness: 0000 0100
I did notice this time that one of the cooling fans starts spinning fast as soon as the ignition is turned on - very reminiscent of a fan control module issue I had on my kids MkIV Jetta (actually the culprit was the High Pressure AC sensor). Assuming the CTS is good (Audi part and only a couple of months old but maybe a bad assumption), what else could cause the CTS to set a CEL and is there a relationship between the other two codes (it's always Bank 2 by the way)? No coolant loss and dash temp gauge is right were it should be. 99700 miles on the car. T-belt, thermostat, and water pump done at 67K.
TIA,
AJG
Last edited by ajg617; Jan 23, 2015 at 10:31 AM. Reason: Wrong forum - please delete
ajg617
Jan 27, 2015 11:42 AM
Cab_and_Wagons
Audi allroad
Nov 12, 2008 08:48 AM
cparke
Jul 23, 2008 06:10 PM
GDJT Allroad^2
Audi allroad
Aug 11, 2007 07:56 AM
Chulsoo
12v V6 Discussion
Dec 8, 2004 02:59 PM
