moving slow forward on D. reverse work perfect.
Old Feb 2, 2015 | 04:46 AM
zachnur's Avatar
Default moving slow forward on D. reverse work perfect.
Hi. Im new owner of audi a6. 2.6cc v6 engine. C4 body.
I change the gearbox oil n put in a new filter. But no change. The old fluid was black. Please help me.
Old Feb 6, 2015 | 01:43 AM
zachnur's Avatar
No one interested to answer my question.?? Or i need to add more details. Please ask what detail needed.. my car also show brake warning with red colour and abs light show up. Please help me..
Old Feb 6, 2015 | 02:16 PM
Rusty Spokes's Avatar
How many miles on the transmission? Year made? What ATF did you use? Let us know.
Old Feb 9, 2015 | 08:26 PM
Prospeeder's Avatar
Are all the dash gear indicators lit up solid and doesnt show what gear you selected? If so there is a fault in the transmission computer and it must be checked, repaired, and cleared.
Old Feb 18, 2015 | 08:04 PM
zachnur's Avatar
Thx for the reply.. My car have 500k+ on mileage. I use dexron lll fluid. I topped up about 5.5l fluid.. measured the temp and fill it up until there is small amount fluid out. The indicator is working fine. It show what gear i choose.
Old Feb 19, 2015 | 01:59 PM
One's Avatar
One
I am not sure what you mean when you say 'slow moving forward'. Do you only get 1st gear? If so, then you may be in limp mode. disconnecting battery for a while should clear that. Also I believe you used the wrong trans fluid. I don't remember exactly but i think you are supposed to use dex V/ synthetic. As to the warning lights, I dont remember if they get turned on in limp mode or not, but the red brake light must be the one that lights up when you pull the parking brake. Unless it is the brake system warning light that i think is a different light from the parking brake light. Make sure your parking brake isnt sticking.
Old Feb 20, 2015 | 11:41 AM
Prospeeder's Avatar
No the C4 audi trans is just dexron III fluid. They are based on the old passat transmissions turned for longitudinal mounting. Dexron VI was not even created yet lol.
Old Feb 23, 2015 | 08:43 AM
zachnur's Avatar
Thx for reply. Mr prospeeder. Really need ur help. My car just move really slow forward. Its acting like it was in 3rd or 4th gear. Very slow movement cant go up to 10km/h also. The red light blinking and abs light keep on. But in R it perfect. If u need any info please let me know. Tq in advance. Sory for bad english.
 Pouria Savadkouei
 Michael S. Palmer
Old Feb 23, 2015 | 12:21 PM
Prospeeder's Avatar
The transmission is in limp mode from a malfunction the Trans computer has picked up. You have to hook up a scan tool capable of reading Audi transmission fault codes. Once you know the fault we can go from there.
twiy
9
Apr 14, 2018 08:25 AM
mikea4
Mar 1, 2011 08:42 PM
mynokiamy
Nov 21, 2005 09:54 AM
rick5ktq
Jul 27, 2004 11:04 AM
