Yellow warning light
I have a 2006 Audi S4 convertible - 4.2L V8
Car seems to run fine. While driving, after about 15 minutes, a quick beep sounds and this yellow symbol appears.
Here is the image.
Check pressures.
If PSI is normal, then...
...Reset TPMS and see if it comes back.
You may have to get a new sensor if it does...
...or if you have VCDS, you can code out the TPMS function.
If it turns out you need a new sensor we have them below!
Click HERE to order or for more information
Jason
