replacing cooling fan switch.
The radiator fan switch and temp gauge are not connected. Two independent systems. There is a another sensor for the temp gauge and the fan switch sensor...
My question is about replacing the fan switch and temp gauge sender and or verifying their operation. I do have a multimeter to use.
Also i am wondering how brittle the radiator might be. Has anyone replaced this switch and do you have advice?
The temp gauge sender (if we are talking a 12v 2.8 V6) is on the coolant pipe passenger side behind the engine. Tight location but changing out the sender is easy enough. The Bentley has a graph with a temp to resistance curve.
See the link and scroll down to:Coolant Temperature Gauge-Overheat Warning: Multi-Function Temperature Sensor (MFTS)
SJM Autotechnik, Audi Technical Service Repair Information
Both units were original '93
Now my temp gauge works and the cooling fans come on at a good temp. The new switch is set a bit colder than the original. That's ok. The temp sender was the original 4 prong that they do not make anymore. Connector very briddle.
