[HELP] 1992 100CS NON Q radiator compatibility
Are the compatible?
Thanks.
I know the early 1992 production year had different rads. Mine is a very early 92, production date of 7/91 and when I had to replace mine I had to get a rad with the extra heater hose size outlet for the oil cooler. I believe the change was made 4/92. I have a 1993 100cs parts car and it does not have the extra water outlet near the bottom. Hope this helps.
Would it be possible to get a radiator from a later build and block of the oil coolant fluid?
Any gurus out there know if this would be possible?
Thanks.
