C4 outer temperature display bulb
Old May 30, 2015 | 01:50 AM
jeesus's Avatar
Default C4 outer temperature display bulb
Hi there
Can anyone tell me, what kind of bulb is used in the dashboard where the outer air temperature is displayed? The bulb is soldered onto the circuit. Also, what's the default color? White?
And would be a good use to know the current passing through the bulb. The local vendor guided me to electronic shop, but they need to know current the bulb works on.
Old May 30, 2015 | 07:30 AM
Rusty Spokes's Avatar
Use a standard T1 12v .060 milli amp bulb. Part number 7219..I get mine off Amazon. I use CML (Chicago Miniature Lighting) as they are, maybe, made in the USA. Some of the China, India and other bulbs life quality is very poor.
See the link:http://www.farnell.com/datasheets/720428.pdf
http://www.amazon.com/CHICAGO-MINIATURE-LIGHTING-7219-10PK-INCANDESCENT/dp/B00DKFMDB6/ref=sr_1_1?ie=UTF8&qid=1432999709&sr=8-1&keywords=7219+bulb http://www.amazon.com/CHICAGO-MINIATURE-LIGHTING-7219-10PK-INCANDESCENT/dp/B00DKFMDB6/ref=sr_1_1?ie=UTF8&qid=1432999709&sr=8-1&keywords=7219+bulb
Old May 31, 2015 | 06:07 AM
jeesus's Avatar
Thanks! Was the right one, though the diameter is too large here in the local shop. Gotta figure out something.
Old May 31, 2015 | 10:44 AM
The diameter is 3mm on those bulbs...are you sure it is too large? Maybe you have a LED in there.
Old Jun 3, 2015 | 06:09 PM
varia's Avatar
12V Microlamps (2-Pack) - Radioshack
Old Jun 16, 2015 | 09:41 AM
jeesus's Avatar
Yeah, got it finally, thanks! Had to use yellow bulb though. Now the problem is that some soldering circuits wore off on the circuit board so I can't really tell, where the bulb should connect or get it's power from. Does anyone happen to have wiring diagram for the circuit? Or very good quality picture of the circuit board?
Thanks in advance!
AK_AUDI_A6
Audi 100 / A6 (C4 Platform)
Oct 29, 2006 03:49 PM
Thane Thayer
Q7 MK 1 Discussion
Oct 2, 2006 04:33 PM
egp320i
Jan 21, 2006 08:19 PM
HyrePower
Aug 29, 2004 05:28 PM
TTyler Durden
Jun 15, 2002 11:07 PM
