S4 (B6 & B7 Platforms) Discussion Discussion forum for the B6 Audi S4 produced from 2003-2005 And B7 Audi S4 produced from 2005 -2008
04 S4 flashing engine light/rough idle pulled codes
Old May 30, 2015 | 04:05 AM
kick3pts's Avatar
Default 04 S4 flashing engine light/rough idle pulled codes
So I start the car up and she's idling like crap. Engine light comes on and starts flashing. I pulled the following codes with VC.
16684 - Random/Multiple Cylinder Misfire Detected
P0300 - 001 -
16692 - Cylinder 8
P0308 - 001 - Misfire Detected
16690 - Cylinder 6
P0306 - 001 - Misfire Detected
17755 - Camshaft Position Sensor 2 (G163) / Engine Speed Sensor (G28)
P1347 - 002 - Incor. Correl.
I swapped the 5 and 6, 7 and 8 coils to try and troubleshoot. Still go the random misfires, CPS 2, and cylinder 6 misfire. Number 8 misfire went away.
Did the timing chain jump a tooth, or is there anything else I should be checking? Thanks
Old May 30, 2015 | 08:48 PM
s4master1's Avatar
Default timing
P0300 - 001 -
16692 - Cylinder 8
16690 - Cylinder 6
can you get a reading from channels 90, 91, 92 and 93?
need to check the cam position sensor first, then the solenoid.
Old May 31, 2015 | 09:29 AM
kick3pts's Avatar
Should the Bank 2 reading be blank?
Old Jun 1, 2015 | 04:36 PM
s4master1's Avatar
Default blank
no, but this may be good as is not getting a reading from the sensor.
possible the sensor has failed or lost connection.
you can swap the sensors very easy just to get it out of the way or test the sensor for resistance.
will go to the shop tomorrow and compare it to any of the 4.2 that come everyday
Old Jun 7, 2015 | 09:34 AM
kick3pts's Avatar
Did you get a chance to check another S4?
beardman
May 9, 2011 02:00 PM
Max_Power
11
Apr 24, 2009 11:42 AM
Gibson6594
VAG-COM Discussion
Aug 6, 2004 04:16 PM
Gibson6594
Aug 6, 2004 08:26 AM
