Hard wired my Valentine
Old Jun 12, 2015 | 07:19 AM
mitchellb2005's Avatar
Default Hard wired my Valentine
Just thought I would share how easy it was to hard wire my Valentine radar and how clean the install turned out.
Rather than pulling the pillar panel off, I used metal spoons to wedge the wires between the pillar panel and the headliner without damaging the wire. Then I ran the wire all the way down the pillar behind the rubber weather stripping. There is the perfect amount of space behind the rubber for the wire.
You can only see about 1" of the wire with the door open, but I plan to fix that tonight.
I spliced the hard wire into the sunroof fuse, and installed the ground with one of the dash bolts behind the fuse panel.
Install took less than 30 minutes. I could have done it in 10 but I was extra careful.
Old Jun 16, 2015 | 07:26 AM
I guess radars arent cool on here lol
Old Jun 17, 2015 | 11:13 AM
ETAzero's Avatar
I was going to hard wire a dash cam just like that. Right around the same spot as well.
they do sell those dash and trim plastic wedge kits online. Also, aren't there a few open spots in the fuse box for new fuses? I haven't investigated it myself yet, still looking for a good dash cam...
Old Jun 18, 2015 | 03:20 PM
just get a GoPro!
Old Jun 18, 2015 | 06:12 PM
Raven8906's Avatar
Looks good, thanks for the tips. I'll be looking to do the same with my Passport Max real soon. I also had the laser shifters installed in my old ride while running escort live on my cell phone. I just picked up this A7 and will be looking to transfer the equipment over.
Old Jun 18, 2015 | 07:33 PM
IknowHuhA6's Avatar
Awesome thank you for the post. Was looking for a solution to discretely hard wire but posts I've found didn't have pics.
Thank you for sharing.
Old Jun 22, 2015 | 07:39 AM
ETAzero's Avatar
Originally Posted by mitchellb2005
just get a GoPro!
lol true. I just want a smaller size and more oval then pull it apart and paint it to match the interior...
Old Oct 21, 2015 | 01:19 AM
blackalak's Avatar
Pics Are gone :-/
 Pouria Savadkouei
 Michael S. Palmer
Old Oct 21, 2015 | 12:42 PM
Ben123's Avatar
Default Another wiring option
Another wiring option is to take down the overhead console. The home link garage opener has a 12 volt supply. I piggy backed off that supply adding a fuse. Since the HomeLink is only powered when the car is on you don't need to turn on and off the radar detector.
s4willburnya
Jun 2, 2005 09:30 AM
lleff
Sep 27, 2003 06:09 PM
Gumbo
14
Mar 23, 2003 08:09 PM
sid horn
Sep 25, 2001 02:02 PM
CPop
May 14, 2000 08:29 PM
