Vacuum lines are confounding me
What a jungle it is... evidently someone jury-rigged it. Are all of those Y fittings and check valves really supposed to be there? One larger plastic line goes the the brake booster and another tees off to what appears to be a crankcase vent hose. I haven't much of a clue as to what all that other junk is. I would like to redo it to make it fit under the engine cover but don't know where to begin.
2nd photo: my 1993 100s non-quattro, manual transmission.
There doesn't appear to be enough plumbing on this one. For example, how does the crankcase get vented? An oil leak has fouled the O2 sensor on that side. It appears that oil is being forced out where a large hose exits the back end of the cam cover.
What do you think?
Regards... Mike
