A6 Quattro Transmission issue
When selecting (D) The car seems to make a turbine sound and does not move... well, it slowly creeps. If you rev it to about 4000rpm it slamms into 2nd gear, I have not done this but the previous owner said it happened once and it was parked for a year. However if you start in (1) and accelerate to about 5mph you can manually shift to (D) and all the gears seem to work fine until you come to a stop. Then you have to select (1) and do the same as previously stated...
Took the car to a certified Audi Tech and had tested with the VAG.
Only code that came up was the brake switch which from what I've read, only means the brake pedal was not depressed before the test, I may be wrong.
Any thoughts or input will be greatly appreciated!
With the transmission warm and engine running..remove the 22mm fill plug on the side of the transmission pan..the ATF level should slightly flow out..if not add some ATF. I had a similar problem after an ATF service on an A6...I was sure the level was fine but is was not. The transmission will rattle too when the ATF is low.
Our Audi transmissions are very fussy about ATF levels. It is worth checking.
The MaxLife ATF from Valvoline is just fine.
