Help with replacing A7s Gear Shifter w/2016s?
Old Aug 8, 2015 | 10:58 PM
asian_A7's Avatar
Default Help with replacing A7s Gear Shifter w/2016s?
After a long day of thinking I'm thinking of replacing my A7s current shifter with what the 2016 has. I didn't see too many videos on how to remove it, but it seems easy. In this video, the guy had to pry down a metal ring to take the shifter and boot off. Now how do pull it down? Is there a point in that ring where you pry it down or do you just pull it down wherever I want? Also how do I put it back up? Do I just make the ring bigger to get back to the original spot? All in all it seems pretty simple but If anyone has done this conversion please provide some help with this.
Old Aug 9, 2015 | 03:08 AM
jjsC6's Avatar
A guy posted in the A6 section a couple of months ago a fairly detailed write-up of how to do it. Do a search on the A6 section. There were a couple of steps that looked a bit tricky, but doable if you are patient and good as such things.
Old Aug 9, 2015 | 09:56 AM
asian_A7's Avatar
I tried several searches and couldn't find it
Old Aug 10, 2015 | 03:50 AM
jjsC6's Avatar
https://www.audiworld.com/forums/q7-...tions-2755803/
Old Aug 10, 2015 | 02:20 PM
asian_A7's Avatar
Any other finds? I found a different one DIY: S-Tronic **** swap
Old Aug 11, 2015 | 03:44 AM
jjsC6's Avatar
I saw that but the instructions were not as detailed. Post pics when you make the change.
5000turbo
Apr 26, 2012 12:28 PM
Dans99A6
Feb 13, 2010 11:18 AM
MC Hammered
Jul 8, 2007 07:01 PM
barrem23
Jan 18, 2003 02:09 PM
audicharlie
Dec 10, 2001 10:23 AM
