Help With VAG Code
P1526 - 001 - Short to Plus - MIL ON
Haven't had much luck searching for a solution to this code, aside from replacing my N205, what does a "short to plus" really mean? Where is the N205 on the 4.2?
Thanks
2004 A8L 4.2L
According to Ross-Tech: VAG code 17934/P1526 - Camshaft Timing Adj. Bank1 (N205): Short to Plus
Possible Symptoms
MIL On
Poor engine performance
Possible Causes
Wiring harness issue
Failed N205 adjuster (electrical)
Failed ECM
Possible Solutions
Ohm test N205 adjuster, see factory repair manual for specifications.
Inspect wiring harness to and from N205 adjuster.
Possible Symptoms
MIL On
Possible Causes
Failed ECM
Possible Solutions
