Passenger Airbag Issue
Old Oct 26, 2015 | 04:35 AM
craignhp's Avatar
Default Passenger Airbag Issue
I have a 2012 A7, and occasionally when I have a passenger, the Airbag Off warning will go off, then after a minute or so, will say it's on again. I haven't talked to the dealership about it yet, just wondering if anyone else has had the issue. This is with different weight passengers, we've tried moving the seat back and forth - up and down - no difference.
Old Oct 26, 2015 | 05:49 AM
snagitseven's Avatar
Super Moderator
Do you have access to a Vag-Com to run a scan for faults? It could be a seat sensor or one of several other causes. In any case, you should get it checked out since it could be a safety issue. You don't want any doubts the air bag would deploy if and when needed.
Old Oct 26, 2015 | 06:44 AM
morski's Avatar
Check under the seat and make sure the connections are still firmly connected together. The airbag connector is yellow. Either you have a bad connection or the seat occupation mat is faulty. As mentioned get it scanned and post it up
Old Oct 26, 2015 | 01:49 PM
Rick Pardo's Avatar
25 Year Member
Same thing happened with my 2013; depending on how my wife sat on the seat (she's all of 120 lbs) the alarm would sound and the airbag light came on. Take it back to the dealer for adjustment. Other than an engine transplant at 1250 miles (flood here in SoFlo 2 i/2 years ago) and the recent MMI 3G upgrade, it's the only significant problem I've had.
Old Oct 26, 2015 | 03:28 PM
hockeyfox's Avatar
Had the exact same issue with my 2012. Dealer WOULD NOT fix it until they drove it for over 50 miles to "duplicate the problem" saying Audi would not cover it until is was replicated. They replaced the sensor in the seat and that fixed it. But for whatever reason when I go the car back, there was no seat belts attached to the front seat. So it sat at the shop another day to reinstall the seat belt. Thankfully since then, no other issues other than a sill plate light going out and replaced under warranty.
Canon
Jun 26, 2011 06:05 PM
clyde415
Audi A3 / S3 / RS 3
10
Jan 27, 2006 10:12 PM
kitora
VAG-COM Discussion
Aug 14, 2003 09:44 AM
thermo
Mar 26, 2003 06:14 AM
ben@speedbarn
Jun 5, 2002 04:13 AM
