Steering Wheel Variants
Old Nov 23, 2015 | 09:57 AM
Odilup's Avatar
Default Steering Wheel Variants
Am I able to retrofit a different wheel with paddle shifters to a 2012 A7 that currently does not have paddle shift?
I have seen information that suggests you can activate the paddle shifter within VagCom to make it work instead of using the shift selector to manually change gears.
Old Nov 25, 2015 | 02:54 PM
Tman007's Avatar
Yes.
There are several threads here that discuss this, with many people doing it successfully. The main tricky part is the airbag if you're sourcing it separately from the wheel -- the airbags alone are expensive and they're different depending on whether you have a flat-bottom or round wheel.
flynavy
Q7 MK 1 Discussion
13
Jun 22, 2020 02:51 PM
IknowHuhA6
Oct 21, 2015 09:50 PM
Penn Dutch
Audi A3 / S3 / RS 3 MKII
24
Jan 23, 2015 09:53 AM
Yoshi123
A7
Apr 23, 2014 06:17 PM
esprssoS4
Feb 27, 2005 09:12 AM
