2013 A7 wont power down
Here is the issue: When I leave the car without hitting the start/stop button the car will go into shutdown mode. MMI screen retracts, parking break goes on, engine stops. If the headlights were on they will turn off after 20 seconds or so... however the LED running lights and tail lights stay on for over 20 minutes and the dash will remain lit up as well. Im not sure if its not recognizing that the key fob has left the car or what but I did put new batteries in both the key fobs. If I lock the car via the fob everything turns off.
See video of the issue:
I should clarify though that like many vehicles, accessories stay on until the door is opened, which I like. On the BMW, even opening the door did not power down accessories unless you pushed the button twice.
Could you please confirm if you have had the car and this is something that just changed? I assume you are putting the car in park then opening the door assuming that everything should shut down without pushing the button at all. I actually have never tried to do that but will go out and try it.
EDIT. Just tried it in my 2016. The engine keeps running when I get out, and even pushing the lock button on the FOB does not shut it off.
