Kufatec Front and Rear Camera Retrofit
I have a 2012 Audi A7 Prestige with the Technology package. I have the rear camera, but I'd like to get the front camera too and the corner view option. Has anyone successfully installed the Kufatec front and rear camera systems? (https://www.kufatec.de/shop/en/audi/...ear-audi-a7-4g) I've searched the forums and found some info (mostly on the rear camera), but nothing definitive.
I'd plan on going to a shop to have the physical camera installation work done. My question is would I need to rely on an official Audi dealer for reprogramming, or is this something that I can do myself with a VAGCOM cable? My dealer has told me that they won't install any third-party equipment in the car. (And please don't start a rant on dealer policies over this.)
I'd hate to spend $2000+ on the kit and installation and then find out it doesn't work.
Thanks in advance for any help,
PTC
PTC
this is it:
https://www.kufatec.de/shop/en/diagn...3g-rear-camera
(You can find it under accessories tab).
the only thing You have to consider is that the current rear camera You have is not the same as the one in the bundle with the front. So You will end up with a spare rear cam (the current one) that will have to be replaced by the new one from the kufatec set. (I think its because the rear only is analogue and rear+front is digital (?) something like that, not sure here)
____________________
From Kufatec -
All codings can be done by VCDS. This kit fits on your car but please keep in mind that you need to replace the existing rearview camera - which is factory fitted to this car, according the supplied VIN - as stated in the item description.
Beside this, this is not an aftermarket system, this is the original system which comes from factory if you choose these options upon ordering. Therefore your audi dealer does not seem to be that competent.
From Me -
So do the other parts you offer, the Diagnostic Interface MMI3G - Rear camera (38080-1) or Codier Dongle MQB / MIB - rear view camera (40264), do the programming? And if so, is there one to code the front camera too?
From Kufatec -
No. You do not need these interfaces. The required coding is described in the installation manual.______________________
Now that I realize it's an Audi part, I may try to work with the dealer on it.
Thanks again for the response.
(probably DE).. because they said it can be done with VCDS, altought they recommend to use their dongle (havent mentioned the manual) .. and the other thing that is a bit disappointing: "if it wont fit Your car, You can return it within 14 days, but we will refund only 85% of the price" -- what?? they must be kidding me...
Take a look:
https://www.audiworld.com/forums/a6-...rofit-2883746/
Take a look:
