final drive fill
I think i have found both of the final drive fill locations, smells like gear lube and some of my research says the same. Im just verifying this is correct.
I dont want to add fluid to the wrong locations..
First pict is the front/side.. i presume its the fill for the 75/90 weight
second pict is the rear with the shaft and seal removed for replacement..
